Agilent 1100/1200 "Configuration Mismatch"
I have recently put a new G1312A binary pump module (from a 1200 system) into an old 1100 system that had a malfunctioning quaternary pump. I connected everything and upgraded the firmware to 6.1x accross the stack, and made sure everything was functioning within agilent lab advisor. Once opening chemstation (B04.03(16)), and updating the instrument configuration, I now have everything functioning except the pump, which shows a grey indicator and when I mouse-over, it says "configuration mismatch".
Also, when I look into the "revision and serial#" menu, everything has auto-populated with the new FW revisions except the pump, which does not auto-populate at all. I'm assuming this is a chemstation issue as the pump will function within lab advisor? Perhaps it is an issue moving from a quat pump to a binary pump?
Very confused here, any help would be appreciated!
What does your instrument configuration shows? Is it the correct module with correct serial number?
In total there are 53 users online :: 0 registered, 0 hidden and 53 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 53 guests
