Look for some forums .
Hi my colleagues,
I am a instrumental analyst in a pharmaceutical lab, I need some website forum about pharmacy、analytical chemistry or drug R&D . I would be appreciated if you are kind enough to help me.
Most instrument & column vendors either put out newsletters, post applications & webinars or at least entertain questions. Other actual forums - there are a couple centered on dissolution testing...
Aicmen,
I have worked in several different fields and in my experience, finding the right forum depends on what you're looking for. This is one of the better because it has a range of subjects. I have found helpful information on all of the instruments I have worked on in the past and are currently using. There are plenty of application specific articles here too. Check out LCGCs application suppliment they come out with every 3 months or so. It's a good starting point Also, I find that vendor websites are better for specific applications. But you may have to contact them directly to get more than just the basic method summary.
Good Luck :)
Thank you for your helpful advice, I'll have a try. Best regards.
