I tested this by processing a sample set using only a processing method. There was a clear calibration line in the sample set between the system suit standards and the first standard so I expected that line to be ignored and a calibration curve built from ALL the standards but it wasn't- the clear calibration line was obeyed despite the Help document contradicting this. What am I missing here? I run in Run Only mode by the way.
