Resolution LC/MS-MS
Posted: Wed Jan 30, 2019 8:40 pm
by pharm2004
I have to separate two peaks at LC Side for LC/Ms-Ms analysis. Can I quantify overlapping two peaks?
Re: Resolution LC/MS-MS
Posted: Wed Jan 30, 2019 10:21 pm
by James_Ball
If the two peaks have unique parent:daughter transition masses then if they co-elute you can still quantify them. If they are isomers with the same transition masses then you need to separate.
