Resolution LC/MS-MS
I have to separate two peaks at LC Side for LC/Ms-Ms analysis. Can I quantify overlapping two peaks?
If the two peaks have unique parent:daughter transition masses then if they co-elute you can still quantify them. If they are isomers with the same transition masses then you need to separate.
In total there are 26 users online :: 1 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 25 guests
