Decreasing Standard Response
Posted: Thu Oct 21, 2004 10:54 pm
I have a standard that appears to be losing peak area over time. Multiple injections from the same vial show a downward trend of about 2% over a 24 hour period. A freshly loaded vial gives a response comparable to the original injection of the standard. The solution was stored at 5°C and the autosampler was also set at 5°C, so both were stored at the same condition other than the container (volumetric flask vs sample vial).
This may also be happening with the sample solutions, but I don't have the repetitive injections of a sample.
Does anyone have any experience with interactions between vials and sample solutions? Any input is appreciated.
