Quantitative analysis of Tph
I am currently facing some problems with the quantitative analysis of total petroleum hydrocarbons (tph)- diesel.
I used to run analysis on the GC-FID for TPH diesel by injecting a range of standards prepared from DRH-TX-002-D-40X . The samples are then quantitated from the calibration levels based on their peak responses integrated under the C10-C28 range. However recently my colleagues sent the same sample to other laboratory for the same analysis and while I detected something in the sample, the other laboratory did not.
I hope that’s someone who is familiar with such analysis can give me a helping hand as to what did I do wrong. The standard checks are fine and surrogates (o-terphenyl) recovery is 100%.
Sorry for this lengthy post and thank you for the answers and help.
Hts123
Did you detect diesel? Did the other lab report a non-detect for diesel? Did they detect something obliviously not diesel?
Can you provide more details? Specifically:
1) What's your calibration range? (Our lab is 200-10,000 ug/mL off instrument with a 20:1 hot split injection)
2) What level was the diesel fuel hit in the extract? Was it just over your detection limit and the other lab had a hit just under?
3) How do you define your quant range C10-C28? We verify ours using an n-hydrocarbon standard containing these compounds to ensure our quant range is accurate.
4) Do you verify your calibration using a second source standard?
5) What's the nature of the sample, soil? water? Is it homogenous? Is it extracted and concentrated in MeCl2 per some determanitive method?
Christian
In total there are 26 users online :: 1 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 25 guests
