GPC Mass Recovery
Posted: Mon Jun 30, 2008 6:26 pm
by Jaries
How do you calculate % Mass recovery on GPC. We are running polyethylene oxide through out GPC columns and i want to make sure everything is coming out and not getting stuck to the columns.
Thank you very much for all the help
Posted: Wed Jul 02, 2008 8:39 am
by HW Mueller
Probably the simplest way to do this is to take out the column, inject and detect a standard at the flowrate used to run the column. The areas should be the same as if the column was involved.
