I need Help in calculating purity threshold in agilent 1260
Posted: Mon May 14, 2018 7:35 pm
by Nahla N.Mostafa
I was making stress degradation studies on a drug and I injected the drug with its degradation products . I selected the ''Select peak purity " from spectrum menu. A figure appeared with a calculated peak purity factor for the peak of interest. The problem was that the purity threshold is labelled as ''set by user'' .I want it to be calculated and I do not know why . I attached a picture from the software to explain the necessary steps to get purity threshold calculated. If anyone could help me to get through these steps
https://www.photobox.co.uk/my/photo/ful ... 0778713050
Re: I need Help in calculating purity threshold in agilent 1260
Posted: Mon May 14, 2018 9:04 pm
by tom jupille
You have to be logged in to Photobox (as you) in order to see that image.
Posted: Tue May 15, 2018 7:40 am
by ydna1977
Hi ,
worth looking at :
https://www.chromforum.org/viewtopic.php?t=23379
and also Waters blog
http://blog.waters.com/get-empowered-re ... hod-tip-34
I have video on PDA but too large to share sorry
