Column Performance.
Posted: Mon May 12, 2008 11:23 pm
Hello All;
I have a issue with my columns, we are trying to develop a standart procedure for criteria of when you have to regect a column or when you need to Regenerate it; I know thres is now a Standart procedure but I suposse that may be USP or FDA have a criteria bese on N; Taling, selectivity; that we can use to determine when we have to get a new column or do a regeneration.
Usually I develop the method and not concern about this; but now I have to help this this.
I will Appreciate you advices.
Thanks and Best Regards.
