Detector problems ?
I have been analyzing water samples for some time with Metrohm Ic. Our column is Metrosep Asupp 5-250, size 4,6*250 mm and particle size is 5,0 µm.
Eluent: 1.0 mmol/L NaHCO3 / 3,2 mmol/L Na2CO3.
Flow: 0,70 mL/min
H2SO4: 0,1 M
When I start Ic and start flushing suppressor channels by pressing the "step" button, conductivity rises to its maximum level. The level has been adjusted to 1341 µs/cm*sec by sofware. This rise also occurs when injecting standards or samples.
Conductivity stays up for ten seconds and then descend rapidly to 16 -18 µs/cm*sec. Sulfate analyzes have been reliable, but there are major problems with nitrate.
We send one sample to another laboratory, and result for nitrate was 0,7 ppm.
Our result was 5 ppm.
The amount of sulfate was moderate 10ppm.
Dear Sir
please check that regenerant and rinsing solution are flowing properly.
Please check that regenerant and rinsing solution are connected correctly.
I rising conductivity after the MSM step quite often indicte that regenerant and rinsing are exchanged.
Dr. Markus Laeubli
Manager Marketing Support IC
(retired)
Metrohm AG
9101 Herisau
Switzerland
In total there are 25 users online :: 0 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 25 guests
