What are the symptoms that a trap is dying?
Posted: Sun Mar 23, 2008 6:26 pm
Purge-trap system w/ Aglent GC-MSD
all of the sudden my early 'gas' peaks are broadening out. I checked to see that all fittings are tightened but I still have this problem.
I've had the trap for a year and I've run lots and lots of samples.
I'm using a vocarb k trap on a tekmar concentrator...
oh, and one other question...
do you use new ferrules when changing the trap? I've bought the new trap and didn't know that I needed furrules. If I'm careful can I just swap the old trap for the new? or should i order new ferrules and be down for a couple of days?
Thanks.
Thanks.
