GCMS troubleshooting...
Posted: Mon Feb 18, 2008 9:20 pm
For about a week now I've been experiencing what seems like a leak, although not sure.
My guess is that I have a minute leak in the transfer line into the MS.
But my chromatorgraph looks like I might have a bad contimination. I changed the helium tank when this started to occur, and unfortunately I changed the column at the same time, so I cannot narrow it down to just the tank. I'm also thinking I might have introduced oil from the tank into the system. I've cleaned the source to see and only a slight improvement.
Just not sure, thought I'd ask here first. I call this the "grass effect" as though the peaks come out fine but you have these plateous randomly.
