Are there any software packages currently available that will control a Perkin Elmer Series 4 HPLC pump? Better yet, does anyone happen to know the RS-232 codes to control the pump? Then, I can make a unified control for the entire LC system in Labview. I've already had some success making a GPC with a Waters 3000 pump, PE LC 95 UV-vis detector, and Alltech MK III ELSD detector.
Al
