water purifiers
Posted: Thu Dec 13, 2007 10:41 am
For GC we need water with low organics, while conductivity and sterility are of lesser concern, but all the laboratory water purifiers that I have come across reduce conductivity and microbial loads as well as TOC, and cost a stack of money. Is there anything out there that takes of organics and does not cost the Earth. What happens if you just put tap or distilled water through an activated carbon cartridge (which is the only part of the commercial systems that does anything to TOC) ?
