Waters Alliance Dissolution-HPLC
Does anyone have experience with either Hanson or Distek dissolution systems with a Waters HPLC direct autosampler? I'd like to get an idea of the reliability of these systems.
I have never used the direct autosampler. I believe it also uses the Alliance HT HPLC. We bought one several years ago in hope of adding the direct autosampler later. I found the HPLC to be troublesome. It either ran extremely well, or if the extra solvent line, which is constantly running, ever had a problem (ran dry) it would take a long time (several days) to get the system equilibrated again. We finally put on a 10L bottle of solvent.
What is that extra solvent line for? Why did you not opt for the dissolution autosampler in the end?
J
The Alliance HT has additional wash and purge solvent lines. If I understand it correctly they continously flush the needle/injector, increasing the ability to make faster injections. We went with Varian baths and autosamplers instead. The autosampler uses HPLC vials and we just transfer them over to the LC.
In total there are 32 users online :: 2 registered, 0 hidden and 30 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 30 guests
