Waters Empower Dissolution Module
Posted: Mon Nov 05, 2007 9:26 pm
by gbalock
All,
I am curious about the capabilities of the Waters Empower Dissolution Module. How complex a dissolution can the module handle? Can it manage an extended release dissolution? Can it do weight corrections calculations? How about multiactive products?
Thanks in advance.
George
Posted: Tue Nov 06, 2007 7:20 pm
by DR
I'm pretty sure it can do all of the above. The only caveat I've found is that it pretty well runs as a macro on a finished result set. If there's a problem with collecting the data that "finish interrupted sample set" can't handle, it won't work for you. There are some limitations inherent in setting up a sample set for dissolution as well, but it generally does a nice job.
