Waters Empower Dissolution Module
All,
I am curious about the capabilities of the Waters Empower Dissolution Module. How complex a dissolution can the module handle? Can it manage an extended release dissolution? Can it do weight corrections calculations? How about multiactive products?
Thanks in advance.
George
George Balock
I'm pretty sure it can do all of the above. The only caveat I've found is that it pretty well runs as a macro on a finished result set. If there's a problem with collecting the data that "finish interrupted sample set" can't handle, it won't work for you. There are some limitations inherent in setting up a sample set for dissolution as well, but it generally does a nice job.
In total there are 24 users online :: 0 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 24 guests
