heptane instead of hexane as eluent?
Dear chromatographists,
Since the use of hexane in our lab has to be minimalised because of health reasons, I was wondering wether it is possible to switch to heptane... Has anyone done so allready and if not, why not?
Kind regards,
Macca
I have used both hexane and heptane.. I had no problems switching to heptane. But beware if you are meassuring fluorescence then you need a pecial Heptane or you'll get a high background.
Kind regards
Leadazide
Other things being equal, I would expect very similar chemistry, but about 25% higher back pressure (due to higher viscosity).
Would it then be wise to increase the temperature by, say, 10 degrees?
Selectivity may or may not change as a function of temperature. Pressure should decrease somewhat. Try it and see.
Depends on the method. When I developed my last chiral method, Heptane and hexane gave me quite different peak shape.
In total there are 15 users online :: 2 registered, 0 hidden and 13 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 13 guests
