Reprocessing data with EZChrom with the <D> filname ta
Hi!
I am planning to use the <D> tag (automatically name the files created
within a sequence with date and time) but find that I can`t reprocess
the data because EZChrom cannot fint the file. It looks for a files named
***** <D>.seq. The question is: Is it possible to use the <D> tag if I
want to reprocess the data?
/AwW
You can build a new sequence "for data file processing". Use EZChrom sequence wizard, it will popup a dialog with desired option. After choosing it, you can select and fill the processing list with your data files.
Hope it helps :wink:
:D
In total there are 60 users online :: 0 registered, 0 hidden and 60 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 60 guests
