acetate and lactate by IC
Posted: Tue Mar 27, 2007 8:51 pm
I've been trying to separate aceteate and lactate by IEC using a Dionex AS11 column and a dilute (< 1 mM) NaOH eluant with conductivity detection. The peaks are poorly resolved and overlapping at higher concentrations. The column literature suggests that this separation should be possible.
Does anyone have any suggestions?
