But I'm also running an HTC PAL autosampler, so it's not as easy as that.
You go under the injector icon in Chemstation and click 'Enable Overlapped Injection' and 'When Sample is Flushed Out' or 'After X min', but that won't do it alone. There's some little setting, *somewhere*, that needs to be clicked on as well. (I've done this before, so I *know* it's doable, but cannot remember that setting or find it in the new machine.)
The CTC method is the same in both machines, so it's not that. And the same applies for the cycle composer.
