- admin
- Site Admin
I need help on trouble shooting peak area reproducibilty. My GC/MS is a Shimadzu GC-17A
model GCMS-QP5000. I'm having problem with peak reproducibilty. Any help?
By Mark on Thursday, July 8, 2004 - 11:53 am:
Teng,
More details might be helpful, i.e. are you using an autoinjector, what kind of injection (split, splitless, ???) detector (FID, MSD, other).
Mark
By teng on Friday, July 9, 2004 - 09:11 am:
Mark,
I'm using an autoinjector. The injection is split, and I using a MSD detector. Any help?
By Mark on Monday, July 12, 2004 - 10:57 am:
Teng,
I should have asked what the RSD values are, typically the RSDs when using a MSD seem to be higher than when using an FID for example. Other concerns might be using too volatile a solvent with too high of an initial column temp., not waiting for the injector to stabilize if you are using a gas saver feature on the GC before injecting the sample. Just some quick thoughts,
Mark
