Ion Suppression
Posted: Fri Dec 22, 2006 2:32 am
by Adelaida M. Molinar
I am a new user of LCMS but 10 years on using HPLC-UV,Flourescence and Diode Array.
From previous post (Neuger),ion suppresion was discussed. I am also having the same problem with Neuger since I'm working on LCMS to determine antihypertensive drug in plasma at a very low conc. (0.5ppb) using liquid liquid extraction. I am having difficulty as experience by Neuger regards repeatability problem and inconsistent recovery.
As mentioned in the forum,the article of Matuswewski et al.,Anal Chem 75 (2003),3019 discuss ion suppresion,can I had a copy of that? or other literature that discuss ion suppresion?
Please help.
Posted: Fri Dec 22, 2006 4:12 am
by Uwe Neue
I can send you a copy of our work on solid-phase extraction, if you contact me.
Posted: Mon Jan 08, 2007 1:37 am
by james little
I wrote an article on ion suppression..
http://users.chartertn.net/slittle/
also, you ought to get a copy of
http://www.amazon.com/Using-Mass-Spectr ... 0849319633
great resource for thinking about the problem..
