Dionex Spectral Array Detector DSA-1
Posted: Fri Nov 24, 2006 1:49 pm
by gctenore
I've got a Dionex Spectral Array Detector DSA-1 and would like to connect it to a PC in order to use the latter as a recorder. Does anybody know if I need special cables or a PC interface or even a specific software for the data acquisition? I thank in advance whoever would like to send me information to this regard
Posted: Sun Nov 26, 2006 8:08 pm
by tom jupille
Have you contacted your local Dionex rep?
Posted: Sun Nov 26, 2006 10:44 pm
by Noser222
What kind of HPLC do you have? Sounds like you are mixing and matching parts, so I'm thinking you need an A/D converter for the analog output of your detector. If you search the web for used instruments suppliers I'm sure you can find something for < $2,000.
