Quaternary ammonium cpd on Primesep 100
Posted: Wed Nov 01, 2006 3:06 pm
Fellow board users,
I'm looking for some assistance and guidance in the analysis of a quaternary ammonium bromide. Some details which describe how this compound has been tripping me up follow.
I'm not certain of the analytes' inherrent hydrophobicity as although retention appears adequate on a 'regular' C18 it shows a large degree of tailing on well endcapped columns such as Luna C18(2) with H2O/MeCN/0.1% TFA. As we had a new column technology in house, we decided to give it a go on a Primesep 100 but have been troubled by an incomplete understanding of retention control on this phase. The first opinion I am looking for from fellow users is can I be certain I am visualising the correct analyte peak? The compound is an aromatic ammonium bromide salt; when I extract the UV spectrum of the (one) peak I have so far been observing it displays a broad maxima around 210-215 nm and has reduced to a negligible value by 254 nm. Does bromide ion have a strong chromophore?
Is Primesep 100 too strong of a cation exchanger for this application? The peak we have been observing has not been sensitive to the amount of TFA in the mobile phase (0.1 - 0.25% v/v), is retained at very high MeCN (is HILIC complicating matters?) and fronts at above ambient temperatures. Should I continue to pursue my method development on this column, or switch to an alternative; perhaps a simple polar embedded alkyl phase.
JA
JA
