dichloromethane
Posted: Wed Oct 25, 2006 11:18 am
by emrl
dear all
i need specific packed column for analysis dichloromethane (methylene chloride)
thank you
ravi
packed column
Posted: Wed Oct 25, 2006 12:36 pm
by chromatographer1
any porous polymer packed column
any methyl silicone column with a heavy loading
any carbopack packed column especially if Carbowax coated
Often DCM has inhibitors, check the label of the bottle.
chloromethane and chloroform are obvious possible contaminants but look for other common solvents, especially acetone and 1-pentene.
Perform analysis at a low temperature but ramp to higher temperature for 'dissolved' contaminants.
best wishes,
