Total polar compounds for edible oil
Posted: Thu May 11, 2017 8:13 am
by mariana
I'm an electrical student and i need information about column chromatography.
I always have errors in my measurements and i didn't find the problem to fix it.
I use ISO 8420 for my experiment.After i finish i put it in vacuum and then calculate the amount of NON polar compounds.
Re: Total polar compounds for edible oil
Posted: Fri Jun 23, 2017 1:24 am
by Arthurjdamico
Tough question to answer if you dont describe the method you are using to analyze the sample.
Have you tried extracting the compounds using a polar solvent to remove them from the oil?
