The attenuation problem - the AIB signal has a maximum signal of ~ 69,000 uV however the signal now tops out at ~30,000 uV in the ChemStation signal.
As for the noise, it is 3x or more than the normal noise and occasionally gets worse, particularly when the signal tops out at 30,000 uV. The same GC has an FID and it is experiencing the same noise issues as the AIB signal.
The problem has been isolated to the 7890B itself. The detector + AIB board was moved to a different GC (7890A) and all the signal problems went away. Also that 7890A's FID has been working properly as well.
Thoughts?
