Can I use splitless liner for split injection?
Posted: Mon Apr 03, 2006 5:51 pm
by zimanli
Is it true that splitless injection would make my injection port dirty faster than split injection? How many injections shall I change liner and spetum?
Thanks a lot!
Posted: Tue Apr 04, 2006 2:14 am
by KC
all depends on what you are shooting and your method parameters. If you are saying you typically run split and are worried about running splitless, no. Under the right conditions I have run literally hundreds of injections with no problem whatsoever, all splitless. Can't remember the last method where I ran split. Make sure you have in your method to open vent after about 30 sec to 1 min. alot depends on your compound and the concentration you are shooting.
Posted: Tue Apr 04, 2006 1:10 pm
by KC
As far as how often to change liner and septum, not until your chromatography tells you to.
Whats the saying, never trouble troubles, till troubles trouble you.
