I am trying to use Sieve for comparing a few samples, though the alignment software it has is skewing things greatly. Looking at a gel map of the peptides, I can see that the 20+ landmark peaks are all 3 minutes apart.
Is there any way to manually change the retention times in a RAW file?
-Tom
