GC/FID TPH (C10-C40) Baseline Shift Problem
Posted: Thu Sep 01, 2016 12:28 pm
i hope that writing right section.
i have a situation about analyses of TPH (Total Petroleum Hydrocarbons) using standard of "Mineral oil standard mixture Type A and B for EN ISO 9377-2" with GC-FID.
The conditions are:
column, DA-5ms, 60m x0,25mm x 0,25um Oven Temp: 40C hold 2min. and 15C/min. to 310C hold 15min.
injection 1ul and split ratio 1/2 Temp: 250C
Detector Temp: 300C
Carrier Gas: Helium
The view of the chromatogram should be below like a hill but,
The problem is baseline do not down after reach high temperature
Thank you in advance.
The conditions are:
Detector Temp: 300C
Carrier Gas: Helium
