Sequence % area in Agilent Cerity for pharm QA/QC.
Posted: Sat Feb 18, 2006 5:25 pm
Hi folks,
I have a standalone Agilent Cerity v2.02 on an 1100 LC, having migrated from a Chemstation v8 environment. I do a mixture of development work and QC work, often using multiple wavelengths.
The development work is mainly using sequences to obtain blank baselines with some qualitative samples to develop or refine in-process control methods. Lots of unique methods.
I'd like to be able to simply generate simple Chemstation type reports with Area % without having to enter any calibration data, stick example chromatograms into methods, or extensively reprocess the data, as reprocessing is timeconsuming ( and unfortunately currently compromising the software stability ).
My naive playing around, along with some local support, hasn't found any simple method, which is surprising, as I had expected the default sequence reports to easily offer area % for a selected wavelength signal, so I'm sure I'm missing something obvious.
Currently, it's quicker to select and reprocess the peak areas using Excel, rather than play around with calibrations. Any pointers to relevant sections of the manuals, Agilent resources, techniques to use, or any other options using Cerity would be greatly appreciated.
Thanks in advance for any suggestions, and please keep having fun,
Bruce Hamilton
Bruce Hamilton
