Help! Thermo Triplus autosampler not following instruction
Posted: Fri Jan 22, 2016 11:20 pm
by laplynn
Hi
I am using Triplus autosampler with Trace GC ultra and encountered a problem with the autosampler recently. After injection of the sample and going through the post washes, the autosampler would move to the vial in the next position, draw liquid from it and dispense into the waste bottle before it returns to its original position. I checked my method and all is fine the way it should be. The status of the autosampler screen says: Waiting ready input. However, my analysis is already running. On the far right of the autosampler, the green light flashes throughout the analysis.
Is there a way to rectify this abnormal problem? Thank you.
Re: Help! Thermo Triplus autosampler not following instructi
Posted: Mon Jan 25, 2016 12:18 pm
by BMU_VMW
most obvious thing to do would be to shut everything down. autosampler, gc, (ms if present), pc and reboot everything.
This should restor communications and reload your method.
