Detalhe CG from MS
Posted: Fri Jan 08, 2016 8:02 pm
I'm working with a Shimadzu CGMS and the column started bleeding. Some people advised me to detach the CG from the MS so I could bake the column without saturating the detector, but my doubt is: How to detach de chromatograph from the MS?
Or, do you have any other suggestion?
If anybody can help, I would appreciate a lot!
Thanks!
Thanks!
