Is this a leak, contamination, or something else...
Posted: Wed Dec 16, 2015 4:08 pm
A couple of days ago the GC-MS was working just fine. Then I checked on my data files from the overnight run and got this noisy baseline.
https://drive.google.com/file/d/0B7ZnVv ... p=sharing
I did a bake on the column, transfer line and MSD, then tuned and still have this readout. I ran an air and water check and a tune evaluation and both indicated that my nitrogen oxygen ratio were low.
https://drive.google.com/file/d/0B7ZnVv ... sp=sharing
However the air and water check has a large hit for 40, I suspected a contaminated Helium cylinder and switched it but no change occurred. What could be causing this?
