Agilent 6890N GC set GC ready state
Posted: Tue Sep 15, 2015 10:04 pm
by pacerlaser
Hello, I am wondering if there is a place either in the GC software or on the GC itself to set the parameters the GC looks for before giving a "ready" signal. I know the Agilent 7890 has an option in the software called "Readiness" but I don't see this with the 6890 GC. Basically I want to choose what parameters need to be within their set points before the GC becomes ready. Thanks!
Re: Agilent 6890N GC set GC ready state
Posted: Tue Sep 15, 2015 11:26 pm
by Himar
As far as I know those options are not available for the 6890. The only real way to ignore something would be to turn it off in the method.
Posted: Fri Oct 09, 2015 5:51 pm
by aidnai
If you are looking to ADD a parameter (I suspect you are not) you may be able to use the auxiliary connector. On the 5890 I believe it is pin 12 -- pull to ground to indicate not ready.
