Agilent 6890N GC set GC ready state
Hello, I am wondering if there is a place either in the GC software or on the GC itself to set the parameters the GC looks for before giving a "ready" signal. I know the Agilent 7890 has an option in the software called "Readiness" but I don't see this with the 6890 GC. Basically I want to choose what parameters need to be within their set points before the GC becomes ready. Thanks!
As far as I know those options are not available for the 6890. The only real way to ignore something would be to turn it off in the method.
If you are looking to ADD a parameter (I suspect you are not) you may be able to use the auxiliary connector. On the 5890 I believe it is pin 12 -- pull to ground to indicate not ready.
In total there are 57 users online :: 2 registered, 0 hidden and 55 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 55 guests
