Groups in Chemstation
Posted: Sat Apr 25, 2015 9:04 am
by kartoffel
Hi everybody,
does anybody know if it is possible to form groups in the chemstation software?
I have to investigate flame retardants (PBDE) and want to quantitate each group (mono-BDE - deca-BDE) seperately by summing up all the corresponding group peaks.
I only know that it works in the chromeleon software and I'm pretty unfamiliar with chemstation.
Thanks.
Re: Groups in Chemstation
Posted: Sat Apr 25, 2015 2:08 pm
by Consumer Products Guy
Yes, GC and LC Chemstation has a grouping function, don't know about the modern GCMS software. I use grouping about 5% of the time. It's not easy for me to explain, but let's say that your group is 70% A and 30% B. The standard is injected. Both would get assigned Group 1 (get the Group column there using Edit Options under Calibration), then you enter in the weight of the group and the software divides it up automatically. Use the Agilent Help, or call them at 800-227-9770 and they should be able to help you over the phone.
Anyway, I then sum up the individual percents to get the total "Group" percent.
Posted: Sat Apr 25, 2015 7:19 pm
by kartoffel
Thank you for your answer. My workmate said it wouldn't be possible at chemstation, so that's some good news for me. I will try that.
Posted: Wed Jul 08, 2015 12:20 am
by pacerlaser
Is there a way to organize the group by retention time? I use Groups for PCB Aroclors and I would like them to be displayed by their retention time but I have not been able to figure out how to do so.
Posted: Fri Jul 10, 2015 1:12 pm
by AICMM
CPG,
Does the grouping require that you assign a peak name to each component? What I would like to do is integrate a slew of peaks, then group everything between say 2 and 3 minutes as one "component". I am currently using area sum but the integration with area sum has issues that grouping peaks does not.
Does that make sense?
Best regards,
AICMM
