I am trying to put together and LCxLC setup using a couple of LC pumps (1100 and 1260), a 10 port switching valve, als, detector. I managed to configure the modules and control everything using chemstation but I just figured that I can't program more than 60 line in a pump method..(the add control is not available anymore).
I looked in to the XML files of each module of one of the method that I was writing and I can see the structure of the program that I wrote; the question is: can I magically add some new lines?
I tried to open the file with excel but the modified program that I created was not read by chemstation.. Has anybody found a nice tweak to extend the program limits given by the graphical interface of chemstation? I have contacted agilent; but I haven't got an answer yet.
Thanks for the help!
