Setting Up Quantitative Analysis
Posted: Wed Mar 18, 2015 1:01 am
Agilent Chemstation E.02.02.1431
I ran 5 standards to set up a calibration table via GCFID.
I tried following the instructions I found here http://www.chem.agilent.com/Library/Sup ... a05214.pdf, but I seem to be missing something. This set up seems to be tailored to MS. I made sure to unclick "Use RTEINT" in the "Set Up Quantitation" box. All compounds have been inserted. After this step, I'm at a loss. I added levels. I used "QEdit Quant Results" to get responses for each peak. Entered the "concentration" and "response" values for each compound. Then, when I selected "Quantitate" > "Calculate" nothing. There's something I'm missing. What makes the FID quantitation set up different from MS. Certain icons, like "AutoQuant Setup" is for MS Data Only.
I get no response for AutoIntegrate or Integrate either. Can anyone point me in the right direction, please?
