Chemstation area sum
Posted: Wed Jan 28, 2015 5:16 pm
I work with a GC 7890A - 5675C MS detector (G1701EA ChemStation).
I would like to create a Time Event or a personal Integration Parameter file (I don't know which is the correct wording) in order to obtain automatically the integration of all the peak's areas between two defined retention times.
I would also like to be able to attribute a name to the sum of those peaks (for example Aliphatic hydrocarbons) so that the integration results appear in the report.
Thank you all for the suggestions and sorry for my bad english.
Nina
Nina
