tablespace issue
Posted: Tue Jan 27, 2015 10:33 pm
I have a Waters 2695 instrument and am still using Empower 2 software.
I have been getting the error message saying 'available tablespace (9.312500 MB) below minimum level to continue processing, Processing Aborted' in the message center since last year. As a result I could not review the datas from that project even if I pressed 'Updated'. To make it work, I have to go to project property and manually increase the tablespace.
Recently the same problem happened to other project as well. I wonder if this is a software issue or a computer issue (not very familiar with IT)....
has anyone experienced the same problem as me before? Any suggestions will be much appreciated!
Thank you!
Thank you!
