Peak96 to OpenChrom
Posted: Tue Dec 23, 2014 6:44 pm
Could anyone provide me with a short tutorial on how to open chromatogram signal data files from HP Peak96 software in OpenChrom?
Where I'm currently stuck:
In my current position I have inherited two HP 5890As and two HP 3396 Series II integrators. I set up an old XP machine to run Peak96 in DOSBox and have the integrators successfully connected and communicating with Peak96 like it would have been in 1989. I can access the export feature of Peak96 to make (*.D) files of runs for Chemstation, but I'm not sure where I'm going wrong because I can't get OpenChrom to recognize the existence or open the (*.D) files even after I've installed the Agilent FID converter plugin.
Thanks in advance!
Thanks in advance!
