Peak96 to OpenChrom
Could anyone provide me with a short tutorial on how to open chromatogram signal data files from HP Peak96 software in OpenChrom?
Where I'm currently stuck:
In my current position I have inherited two HP 5890As and two HP 3396 Series II integrators. I set up an old XP machine to run Peak96 in DOSBox and have the integrators successfully connected and communicating with Peak96 like it would have been in 1989. I can access the export feature of Peak96 to make (*.D) files of runs for Chemstation, but I'm not sure where I'm going wrong because I can't get OpenChrom to recognize the existence or open the (*.D) files even after I've installed the Agilent FID converter plugin.
Thanks in advance!
Andrew Boyd
Development Chemist
Applied Catalsyts Inc.
Try ours
http://www.unichrom.com/chrom/uc-ffe.shtml
At least we can read *.ch *.uv *.d and *.ms
http://www.unichrom.com/dle.php
Data processing is free.
Btw i had a question from person who has
HPIB controller <->HPIB-HPIL converter <->HP-5890 with 19242-HPIL.
As far i know this construct is managed by Peak96.
I'd like to reverse this thing to make possible UniChrom control of HPIL-only instruments.
Hi Andrew,
feel free to contact us via our website http://www.openchrom.net. If you send us some test files we can check where the import goes wrong.
Best regards
Andreas
Hi Andrew,
Best regards
Andreas
Andreas,
No one has responded to my attempt to contact you through your website. I would like to send you the files I am generating.
Andrew Boyd
Development Chemist
Andrew,
please try again contacting us via "info [at] openchrom . net"
Best regards,
Andreas
Users browsing this forum: lmh and 24 guests
