Star Workstation 6.41 Integration Report
Posted: Wed Sep 17, 2014 9:14 am
by Monty_Python
Having a little problem....
We're running a Varian ProStar HPLC (gradient system with 335 diode array UV/Vis detector). It used to be that when the method was complete it would output a TXT file with the integration results in it (the same that you get if you open the chromatogram in the viewer and then right-click/export data as ASCII).
What am I missing?
Re: Star Workstation 6.41 Integration Report
Posted: Thu Sep 18, 2014 4:47 am
by DoryFish
Hi, we don't print reports so apologies if this doesn't help:
In the method editor window, if you go to the PDA control section, under the relevant Channel do you see section called "Standard Reports"? There's a whole series of headings including "print options", "calibration block report format" etc which have various selections relating to how the reports are printed.
Posted: Thu Sep 18, 2014 9:35 am
by Monty_Python
Been through all those options, none of which appear to make any difference. What I have noticed is that at the end of the run, this appears a the bottom of the screen:
Autolink command REPORT32.EXE -rai CHEMIS32 not installed or cannot run
Any ideas anyone?
