hissing split vent on Agilent 7890
Should I ever be able to hear gas coming out of the split vent on the back of the 7890? Pressure too high?
We have a new 7890 and I haven't heard this before on our other 7890.
Hello
If you don't have massive leak there is nothing to worry about...It is normal for S/SL inlet. The bigger spit ratio you have, the bigger split vent flow you'll have (and sometimes you can even hear it)
Just be aware that you should use "gas saver" option to save carrier gas.
Tomasz Kubowicz
In total there are 42 users online :: 1 registered, 0 hidden and 41 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 41 guests
