Agilent 6890 detector output not displaying
Posted: Thu Aug 28, 2014 12:02 am
We have a 6890 dual GC. Both detectors appear to be working fine on the instrument itself (have a non-zero output). However, on the computer program, the signal 2 says N/A on the window where the spectrum is recorded. Signal 1 says "front detector" and I can see the detector output in real time. Any idea on how to get signal 2 (the back detector) to show up on the computer?
Also, if I try to run a sample on just the front detector, the FID file isn't being recorded. I'm guessing these problems might be related. Thanks!
