Column Manager question: Problem with column active heater o
Posted: Tue Apr 01, 2014 8:50 am
Problem with column active heater of HClass System
Problems instrument:
- the column manager does not respond to temperature regulation bringing the column to maximum temperature.
Software problems:
- Empower records only the room temperature;
- Empower does not allow to change the temperature of the column because the Column Manager section is not reported;
- Empower acquires only the data of "Sample Manager" and of "Quaternary Solvent Manager".
Any help would be appreciated. Thanks
Software problems:
