PMS for GCs
Posted: Mon Jan 27, 2014 10:59 am
by abuzuhaira
Hi all
I am intending to develop a PMS (Schedule, or Calender) for the GCs mainly and other equipment being used in our lab.
any recommendation
regards,
Re: PMS for GCs
Posted: Wed Jan 29, 2014 3:26 pm
by James_Ball
Hi all
any recommendation
regards,
Preventative Maintenance will vary greatly depending on what type and how many samples you run each day.
We run 50-75 injections each day and over night so we pretty much change the lnserts daily. When I ran 8270 GC/MS we changed them daily along with clipping about 4 inches of column daily. Septa are usually good for 100-300 injections depending on temperature of the injection port.
If you have a log book from the last year where you preformed maintenance as needed, look through that and get the average time between maintenance and take about 70% of that and make it your schedule. That should cover most problems you would normally encounter before they happen.
